Using Funnels as Stands for Loading a Bialetti Moka Pot
- drgary
Here's a way to make the loading of a moka pot neater and easier by using funnels as stands. I'm using a six cup Bialetti that uses 1 cup of water to the boiler's fill line.
This small metal funnel makes a perfect stand. It's the largest one in the Norpro Three-Piece Funnel Set that's available for less than $10 online. (It may be the funnel provided with the new Olympia Express Creminas for filling the boiler.)
This is the Norpro Stainless Steel Wide-Mouth Funnel. It also perfectly fits a 58mm portafilter and costs less than $9 online.
After I pour in my ground coffee I tap it on a rubber tamp mat to distribute the grounds before removing the funnel. Then I complete distribution with a finger and flatten the coffee into the filter cup with my palm. The coffee grounds are not tamped in a moka pot. I use an Orphan Espresso LIDO 2 grinder at one full turn for moka. From memory, a Baratza Encore grinder takes a setting of about 12 to 14. I dose the cup with 2 1/2 Aeropress scoops of beans before grinding.
I like to use an Aeropress funnel to hold the moka pot top.
This is useful when adding an Aeropress paper filter for a cleaner and healthier* cup. I prefer the cleaner taste. To add that filter I wet it first and put it over the metal screen that's held in place with a rubber gasket. (Don't put the paper under the screen, which can cause a Bialetti sneeze.)
* Paper filtering is recommended by Aeropress inventor Alan Adler to remove coffee's cholesterol raising properties found in cafestol and kahweol. See this thread for that lengthy discussion, which I don't want to continue here.
The effect of espresso drinking on cholesterol
LMWDP#308
LMWDP#308
- dcupstateNY
Gary, does that filter, in anyway, prevent the gasket from properly mating with the water reservoir?
Ciao,
Dave
LMWDP: #346
Dave
LMWDP: #346
- drgary (original poster)
LMWDP#308
LMWDP#308
