Pre-infusion, or water feed, for dummies
Hi Everyone,
I need to set up a stand to accept bottled water to feed a LSM rotary pump (Procon) espresso machine. I've looked through several pages trying to find the summary thread that was posted that shows a great "how-to" for those with machines that should be, but cannot be, plumbed in.
My recollection is that there is a great how-to (CannonFodder?) that summarized how to start with a 5 gallon jug of water, pressurize it with a small flowjet like setup, put it into a preinfusion bubble chamber at 2 atmospheres or so feed to the machine, and where in the setup to put the charcoal filter and paper filter. thread included electrical and stop valve recommendations. I can't seem to find it.
Dan, or others, if you could find the link I would be most grateful.
Regards,
PocoJoe
Regards,
PocoJoe
PocoJoe
Safety Third- First Roast, then Grind
- cannonfodder
Not that I recall doing. I did on on how to plumb in a float valve so you do not need to refill a reservoir fed machine among other. This one is in the FAQ
Do most plumb-in machines require external pressure?
YES! thank you- not exactly what I remember, but it made reference to the foot valve and that is what I was trying to recall the name of. Many thanks, case closed.
PocoJoe
