Are KYM bakelite grinders any good?
- zix
Have been looking at eBay KYM grinder offerings for a couple of days, and it seems like the KYM bakelite grinders in general are priced higher than the wooden ones. Like this one for instance:
http://www.ebay.com/sch/i.html/?_nkw=ky ... %20grinder
It looks really nice, but can it grind for espresso, and... would it stand up to daily use? Or is it just something that collectors like because of the nice design. Does someone here have some experience with the Bakelite models?
LMWDP #047
- grog
I didn't see one of the Bakelite models in the link you posted, but yes, in my experience they do work for espresso. As far as I know there are two versions: the small white 'milly' (also sometimes seen in green and salmon) which appears to have been intended as a travel grinder; and the larger brown ones which remind me of a knight from a chess set. The Millies can often be found for around 30 bucks, while the 'knights' are at least double that.
As with any vintage hand grinder, there is no guarantee that a given example will 'definitely' grind for espresso...but I've had excellent luck with Kyms, have both of the aforementioned models, and the ones I own grind to Turkish powder.
LMWDP #514
- Eastsideloco
+1. They must cost more because buyers consider Bakelite items to be more collectible. But they work like any other KyM mill.
My experience is with an older model:
http://www.flickr.com/photos/21519888@N ... 3513005389
The grinding mechanism is identical to a wooden KyM mill from the era and is capable of espresso. Personally, I like a hand grinder with a wide based for espresso, especially if I am using lightly roasted beans. So ergonomically speaking, this is my favorite KyM mill:
But the Bakelite model is one of my favorite designs. While I do think the Bakelite models are capable of holding up to daily use, I've never used one for weeks or months on end.
- orphanespresso
- Sponsor
Small note - vintage bakelite does not ever come in white. As Bakelite (or any vintage phenolic resin) ages, it's color tends to change/deepen. Tans will become browns, white becomes butterscotch, yellows tend to green - red stays red, and black stays black. White would be plastic, not Bakelite. Watch out for cracks on vintage Bakelite grinders.
Doug Garrott
www.orphanespresso.com
- zix (original poster)
I seem to have made two mistakes here: first of all, posting in "buying advice" instead of "grinders" forum. Well - it is a kind of buying advice, but still, not quite what I intended. Secondly, posting a faulty link. Sorry!
Yes, it is the brown "chess knight" kind I am talking about - item number 290850432555 on eBay is the one I tried to link to.
Oooh, cracks in the bakelite would not be good at all, especially if they crack in the wrong place, like for instance in the inner chute where the lower burr is.
Perhaps better off looking for that 'ergonomical' one. It is a beauty!
LMWDP #047
- peacecup
Mats - check your PMs- plenty of vintage grinders here on the big lake for you to try.
Jack
Jack
LMWDP #049
Looking good, PC!
Thanks for moving the thread, HB!
LMWDP #047
