Is there a trick to disassembling a Parker 3-way solenoid?
- stefano65
- Sponsor
First unscrew the extension
the the coil then you will have access to the pilot which can be unscrew from the base
PS that valve looks like it has had much better days
Stefano Cremonesi
Stefano's Espresso Care
Repairs & sales from Oregon.
- Randy G.
hehe ya it appears to have suffered some kind of short and blew up a little bit, it's on a project machine I'm finishing up. I'm hoping something can be salvaged.stefano65 wrote:First unscrew the extension
Alright, I'll try unscrewing this thing.
Thanks
Ok got it apart, thanks! And thank channel locks
Looks like I'll be ordering a new coil from Stephano soon. I think the pilot looks ok and I'll just clean it up.
I do need the wired portion that plugs into the coil too though as it appears burnt, not sure where to find one though, it doesn't look like Stephano carries it?
Here it is blown up:
- stefano65
- Sponsor
Since you are talking about ordering from us (thank you in advance)
before ordering
do make sure you can clean that pilot, it looks pretty bad,
and not to try to be negative but sometimes even when they look clean they might still not work properly
so it might be easy to say it for ME and I do not intend this as a sell pitch
but If I was you I will replace the complete valve
in regards of the connectors you can see them in the same section on our web page were the valves are
thanks
SteFano
before ordering
thanks
SteFano
Stefano Cremonesi
I know what you mean. I think though that the pilot looks great, barely any scale (and it all cleaned off in citric acid) and the o-rings are still soft, spring and all that moves easily. I still haven't opened up the other group's 3 way yet, however it looks good so I may wait to see how it works first.
