La Marzocco Strada basket
I purchased a La Marzocco Strada Medium, or 16 - 18 gram basket. I always weigh my dose to 18 grams for a double shot, and I never have enough grounds to form or shape, or level the dose before tamping. I level it while I break up the clumps with a toothpick or pin, and then tamp. I get a little channeling and spurting. I am getting good pulls, and they taste good, but the pucks are pretty wet, and do not hold their shape when I dump them. Am I doing anything wrong, or just how the new basket works? I have a Rancilio Silvia and a Super Jolly.
- HB
- Admin
If you're concern is wet, sloppy pucks, there's no need to worry. See previous "wet puck" discussions for more details. Below is an excerpt from one of them.
cafeIKE wrote:Finer grind and lower doses = wetter pucks.
We tend to worry about the taste.
HB wrote:Ian's right, there has been a rash of posts expressing concern about puck appearance. I will add it to the FAQs. Below are some previous discussions:
Wet, glunky pucks
How do my pucks look?
Wet pucks: Do beans make any difference?
I've not discovered a correlation between the appearance of the puck post-extraction and the taste of the espresso. Moreover, there's nothing inherently wrong with small puddles of water on the puck's surface, though it should be consistent from shot-to-shot. That is, if you see big puddles one time, dry as sand the next, that's a problem. But if the puck's surface looks and feels basically the same each time, I believe you've exhausted the value of "puckology."
That's why I am wary of claims that one can see evidence of channeling on the puck's surface. Afterall, most espresso machines have 3-way valves and they depressurize from 130 PSI to 0 in an instant. I think that any fissures are as likely caused by rapid depressurization as channeling during the extraction.
- shawndo
If it tastes good, don't worry about it too much. But in the spirit of experimentation, I would try and up the dose just to see how the taste changes.Mochamaker wrote:I purchased a La Marzocco Strada Medium, or 16 - 18 gram basket. I always weigh my dose to 18 grams for a double shot, and I never have enough grounds to form or shape, or level the dose before tamping. I level it while I break up the clumps with a toothpick or pin, and then tamp. I get a little channeling and spurting. I am getting good pulls, and they taste good, but the pucks are pretty wet, and do not hold their shape when I dump them. Am I doing anything wrong, or just how the new basket works? I have a Rancilio Silvia and a Super Jolly.
I would get channeling and a wet puck with a low dose in a strada basket, but it was also underextracted, so didn't taste right.
Strada branded baskets should be marked with a dose weight on the side. They come in 7,14,17 and 21 denominations. Does it actually say "17g" on the side ?
Darmok and Jalad at Tanagra
