Two stage metal filter brewing
- EricBNC
Over on Kickstarter there is a double filtration pour over that provided me with some DIY inspiration. I have a 500ml Boneco pourover with a built in seriously fine mesh flat bottom filter - so fine it's easy to stall the brewing so it sat on the "things I look at" shelf until today.
I put a SwissGold #4 filter on top of the Boneco to provide primary filtration while the Boneco's mesh filter provides the final filtration. Here is a photo of the last sip from a 500 ml water, 30g ground coffee pot:
By the way, that's a Bodum double wall espresso shot glass...
LMWDP #378
Author of "The Bell Curve: Instructions for Proper Herd Mentality"
- TomC
It's a trap!!
What did it taste like?
- EricBNC (original poster)
Like press coffee minus the grit!
Clean up is very easy too.
LMWDP #378
- TomC
Yes, I was tempted to use the meme too.
