Proteo Grande Parts
Hello all! I have an old Proteo Grande machine that needs some new gaskets and a new water reservoir. I've tried to reach out the manufacturer with no luck via their email , info@g3ferrari.com, and the form on the website. Does anyone have a suggestion on what I can do?
Those were made by Saeco. Most of the parts and seals are interchangeable and easy to obtain.
Try Stefano's espresso care or Parts Guru. One of them should have what you need.
- another_jim
I vaguely recall some of the *$s machines labelled this way being Gaggia Coffees. If that is the case, it's also easy to get parts. The basket for the Saeco has a 53mm diameter, for the Gaggia, a 58mm diameter, so it's easy to check which it is.
Jim Schulman
Looks like Jim is right. If you go to Parts Guru website, it looks like the Gaggia Carezza.
Thanks for the help. I'll check with Parts Guru today. I really need a new reservoir in addition to seal and such. Hopefully they will have one.
