Pourover methods that can use fine grind setting? - Page 2
Going from fine to coarse was never a problem for me. It was always been going back to fine from course.
Your supposed to have the grinder running when you change settings. That wasted a lot of beans.
With the grind chamber clean, I find that it goes back to its fine (espresso) setting vary constantly.
That seems to be the most common complaint about the Vario.
These days I'm playing the Vario against the Lido in the course range.(using the Clever) But the Vario only goes to drip to course drip range. This is where I think the Vario starts falling apart. But I haven't tried enough different coffees to know for sure.
I've had more luck adjusting when single dosing than when the hopper is full, but it's always a gamble as to the accuracy it adjusts with.
LMWDP #366
I didnt think about it till now, and its not exactly what you asked for, but a cold dripper may work in your favor. The grind is held back by a ceramic disc, which acts as a filter. The rate of flow, however, is managed by the user via a stopcock. Ive had drinkable cold brews that were way outside the parameters of what is considered acceptable for hot brewing, so its possibly more forgiving.
LMWDP #366
I also use a Vario W for pour over grind and espresso grind. Works for me!
I'm not interested in French Press or anything that really calls for especially coarse grounds so I think the Vario fits my uses.XCman wrote:Going from fine to coarse was never a problem for me. It was always been going back to fine from course.
But yea, like you said, I've heard issues mostly about going back to fine grind settings (even with grinder running during adjustment as it is supposed to). I wonder if this has anything to do with the calibration screw getting vibrated out of place (and if thats fixable with some blue thread lock)
Maybe its time for me to reconsider single dosing.. hmmpacificmanitou wrote:I've had more luck adjusting when single dosing than when the hopper is full, but it's always a gamble as to the accuracy it adjusts with.
Original plan was to grind into a scale, save the proper time, and just dose that way every time.
I'll probably be too grumpy in the morning to mess with beans, scales and single dosing but we'll see what happens.
This will be interesting for the coming spring/summer months hmm. Thanks!pacificmanitou wrote:I didnt think about it till now, and its not exactly what you asked for, but a cold dripper may work in your favor. The grind is held back by a ceramic disc, which acts as a filter. The rate of flow, however, is managed by the user via a stopcock. Ive had drinkable cold brews that were way outside the parameters of what is considered acceptable for hot brewing, so its possibly more forgiving.
Is your Vario hit-and-miss when returning from pour-over grind to espresso grind? And do you single dose or no?Bodka Coffee wrote:I also use a Vario W for pour over grind and espresso grind. Works for me!
You could get a set of pinch bowls and weigh out a couple doses the night before so its streamlined when you're half asleep. A vario has such low retention you don't need to check the output weight as carefully as other grinders.
LMWDP #366
I don't preweigh with the W. I don't go back and forth between po and espresso often enough to tell if it changes much. The beans age and that may make more difference in my case than the drift in the Vario.
