Shame on me. I killed my Cremina. - Page 3
Well, I decided to go ahead and try to make the gasket fit. All worked out ok since the gasket is very soft and stretchy!
Tightend everything up, crimped a ring terminal onto my ground wire and placed it underneath a element flange bolt, added water and fired it up. It works fine! Not popping GFCI outlet.
I ended up bending the draw tube so thanks for saving me from cutting it down!
The Cremina is back in business!
No prob... Glad I could help and most of all good to see the problem is solved!!
If I could just like crappy coffee again, it would sure save a lot of time and money!
