La Pavoni Jolly burr measurments
Hi All,
What are the La Pavoni Jolly burr measurements? I see 50mm OD, but is 50mm x 30mm x 8mm like the Rancilio, or maybe 31mm ID, I've seen 7.5mm height mentioned as well. Same 3 screw pattern will fit?
I would buy a Jolly but I want to be able to get the burrs down the road. Thanks if someone has the Jolly to confirm!
I can't seem to find the burr's by the part number 455000 for sale on line.
Roger
Roger
- jfrescki
Espressotec says
.Large 2" dia. burrs (same as the Rocky)
Specs: Burr Diameter 50mm
Write to your Congressman. Even if he can’t read, write to him.
- Will Rogers
- Will Rogers
OK, wish there was a few more details there, I found some other site with 50 x 30 x 8 mentioned, 7.5 all over the place too, looks more promising. Maybe both work, anyway both available once I have the grinder, I'll just measure them.
