Baratza Vario-W belt cam loose!? Set screw missing?
- JavaMD
My Baratza Vario-W started making "slipping noises" and didn't grind.
Took the back off the unit and found what looks like a "set screw" hole in the cam that is attached to the motor.
The cam turns the belt.
I went to Home Depot and found a 4mm set screw ... but want to make sure that this is what I should do ... Any thoughts? Thanks in advance. Can send it back to Baratza but if it is just a set screw missing ... could save myself $90 repair fee. Weird thing is ... I can't find a loose set screw in the grinder.
Picture of the "set screw" hole and cam below ...
The very same thing happened to me. The set screw is probably still in there somewhere, hiding. I eventually found mine after replacing it
Having said that, I wouldn't hesitate doing what you've suggested.
- JavaMD (original poster)
Thanks Much! just got to head back to the hardware store and get one shorter than 8 mm in length to be a bit more balanced. won't stick out so far. Looked deeper than it was.
Steve
Steve
Works great ... just want to mention that the set screw that fit was a 4mm screw with 5 mm length that took a 2 mm hex wrench to turn it.
This happened to me too but my screw didn't fall out, just had to re-tighten it. The guys at Baratza said it should have been "Loc-tited" in there but this one was missed.
Check if the missing screw isn't stuck magnetically to the motor, that's happened to me too.
Thanks ... good Idea to put the loc-tite on it ... will look again for the screw ... would hate to have it end us somewhere it shouldn't
steve
steve
