La pavoni pw-16 - has anyone used one?
I am wondering if anyone is familiar with the La Pavoni PW-16?
I discovered it by chance while browsing Amazon and I am guessing it is a newer offering as I can only find one review for it.
It looks to be a lower end machine for La Pavoni. It has a plastic body, so I assume this is part of the reason it is less expensive. But it sounds like it has some very nice features nonetheless. The description claims: "A state of the art, pressurized coffee handle, allows you to use any type of ground coffee to achieve triple the volume of "crema" normally made by other home espresso machines."
I am looking for a replacement for a Gaggia Dose right now and hoping I can find something for under $600. Of all the machines under that price I've browsed so far this is the one that has most caught my attention, but I am a little hesitant to order a machine for which so little user feedback is available.
I tried to buy one once off of ebay and the shipper didn't pack it right so it got busted in shipping and I never got to try it. It has a pump and a pressurized portafilter. I saw someone selling one with a regular portafilter in it once.
The pressurized portafilter by my understanding won't open until it hits a certain pressure so it takes away the finickiness of getting the right tamp.
So I can't help much, from what I read it was a decent machine. It may not satisfy the pure espresso crowd but I am guessing it can make a decent latte which is what I was shopping for. I am sure other can jump in on the pros and cons on pressurized portafilters that I know very little of.
I would avoid it. Its a decidedly consumer device that can't make a true espresso well. At your price point, options are limited without a willingness to buy used and restore. I'd recommend a pavoni EP or similar.
LMWDP #366
Thanks for the suggestion Brandon. I can't find any place selling the "Pavoni Espresso Plus." I am even having a difficult time finding information about it. Is this machine still manufactured? Do you have any other suggestions?
I should add that I don't drink lattes or caps, just straight espresso. I really don't need a hot water dispenser/frother, in case that makes any difference in the machines I should consider.
EP is shorthand for the europiccola, pavoni's small lever. What is your drink volume and budget, and are you willing to buy used?srevli wrote:Thanks for the suggestion Brandon. I can't find any place selling the "Pavoni Espresso Plus."
Also, you must consider your grinder. What will you be using
LMWDP #366
- drgary
Chris:
Here's some "must" reading that will educate you about options:
How to choose an espresso machine and grinder at the "right" price
Don't get anything with a pressurized portafilter. See some of the FAQs and favorites for this Buying Advice forum.
LMWDP#308
LMWDP#308
