Pump replacement - S1 pump valve and spring
I'm replacing the pump on my Andreja Premium and thought I'd take the S1 pump valve off to descale it. I'm referring to part 110 in this diagram /downloads/ ... _Parts.pdf
As I took off the tube that leads to the boiler, a tiny spring and plastic piston dropped out. Of course, I didn't fully catch how they were seated so I thought I'd double check before putting everything back together again.
This photo shows what I'm talking about:
I've placed the spring and plastic stopper/piston as I assume they should be assembled. Is this correct?
Thanks,
C
Thanks,
C
- erics
- Supporter ★
