Wiring La Pavoni 1980 with white switch/black switch
I have a Pavoni from 1980 and the problem is the white switch is not working anymore so I had to change it. Because there is only a black switch to buy I have a problem with the wiring diagram. The wiring diagram for the white switch is like in the picture. Does anybody know the wiring diagram for the black switch. Thanks in advance for the answers.
- homeburrero
This post:
La Pavoni Europiccola 2-element wiring diagrams
shows the wiring diagrams for both the black and the white switches.
Pat
I tried that but still no result ;-( But thanks for the help
- homeburrero
Are you saying that you wired it according to the diagram for the black switch, and that did not work? If so, post a picture of how you wired it and we may be able to help.MIckieF wrote:I tried that but still no result
Pat
- homeburrero
Looks to me like you have the top element wires right, but need to swap the two bottom wires (furthest from camera.) On the black switch, the wire from the cord should go to the side of the switch closer to the boiler.
Pat
