Low caffeine blends for espresso
- trihard
Hi All,
I was wondering if anyone knew of or is using a low caf blend? I used to use Speedbump by Deep Cello, and when they went away I moved to the African blend by Badbeard (same roaster as DC). Are there any other low caf blends out there that work well for espresso?
good question,
I wonder if the answer is to blend some mild decaf coffee that can serve as a good base with blends that you like.
