Mini Vivaldi II steam boiler issue
Hi, I'm having a problem with my "new" (previously owned, but new to me) mini vivaldi II. When I try turning on the steam boiler, the pump runs, but after about a minute, it stops and all lights turn off except for the "Boiler" light, which is blinking. The manual stated that this is an issue with the automatic boiler refill. After a few tries of turning the machine off, then on and trying again, the boiler was working and could steam and pull hot water. However, the issue started again a while later and i'm not sure what to do. I bought the machine used on cragislist, and the date on the machine is 1/2010. The seller claimed to have recently cleaned the machine, however I do not know what was cleaned or how long ago it was. I have already called the seller, and am waiting to hear back. I may end up just getting my money back. What other options would I have? Has anyone else had this issue?
Thanks!
Thanks!
- bean2friends
Check out S1cafe.com - join it and post your question there after doing some searching. I'll bet you'll get the help you need there.
You can also try calling Chris' Coffee Service's tech department. They know the vivaldi inside-out and are very helpful.
