Recovering a Dalla Corte Mini - Page 2
When I look at the specs for those brushless DC pumps, I don't see that any will go down to the desired flow levels for flow profiling without using an over pressure valve. Just an observation...
- Carneiro (original poster)
This one works, as you can control the motor. At a desired pressure with minimal flow, the gears will "slip" maintaining the pressure.
Specifically, I was looking at the listed minimum flow ratings. All higher than the ~1.5 ml/sec that I like to see.
But I think this is minimal free flow...
Makes sense, thanks.
If anyone is working on flow profiling and needs help on the programming, let me know.
