by cannonfodder on Thu Apr 21, 2011 10:38 pm
A basket, is a basket. Different brands can have slightly different depths so you can get more coffee into them but a new basket will not fix things like distribution issues. The most common is the Faema style double with the sloped base, the marzocco ridgeless is the same basket just a little deeper. The marzocco triple is a straight sided basket, a marzocco double is also straight sided but is 57mm so you need a smaller tamper to make it work. If you simply dont like the positive snap you get from a standard ridged basket you can take the retaining spring out of the portafilter and drop the basket in. Baskets have been discussed at length. If you run a search for basket types or portafilter baskets you will get pages of discussion.
