Working with the ridged La Marzocco double basket
Postby mitch236 on Mon Aug 30, 2010 3:15 pm
I have been trying to work with Black Cat beans this week. Malachi recommends a 17gm dose but when I try to tamp that amount in my ridged double basket, my tamper hits the ridge. Is that a big issue? The coffee tastes good and I don't seem to have any big extraction issues.
mitch236
Postby HB on Mon Aug 30, 2010 3:18 pm
La Marzocco aficionados recommend a 57mm tamper for the reason you cited.
Postby Marshall on Mon Aug 30, 2010 4:22 pm
Or a Faema/Synesso basket.
Marshall
Los Angeles
Marshall
Postby tekomino on Mon Aug 30, 2010 4:55 pm
I use 57mm tamper just for that. I prefer ridged basket to Synesso ones but if dose is at 16 grams or less then 14 gram Synesso is right tool.
Refuse to wing it! http://10000shots.com
tekomino
Postby Nik on Mon Aug 30, 2010 5:32 pm
Interesting.....I use the Synesso ridge-less triple and double baskets and a 58+ size Torr european curve tamper and it fits perfectly. Their 58+ size is 58.6mm. Doesn't scrape the sides and does a much better job at pushing the grinds from the inside edge of the basket. It nutates and polishes perfectly. The slight curved seal on the edges is effective as well.
I have 58mm Espro and Speedster tampers that I seldom use.
Nik
Postby mitch236 on Mon Aug 30, 2010 7:13 pm
Nik wrote:Interesting.....I use the Synesso ridge-less triple and double baskets and a 58+ size Torr european curve tamper and it fits perfectly. Their 58+ size is 58.6mm. Doesn't scrape the sides and does a much better job at pushing the grinds from the inside edge of the basket. It nutates and polishes perfectly. The slight curved seal on the edges is effective as well.
I have a few Synesso baskets and have to say, I'm not in love with them. I seem to have better extractions on my equipment with LM baskets.
I guess I have to order a 57!!
mitch236
Postby cannonfodder on Mon Aug 30, 2010 10:42 pm
The standard LM double basket takes a 57mm tamper. The ridgeless double and straight sided triple take a 58mm tamper.
cannonfodder
Return to Tips and Techniques
