hypersoar wrote:..and grind settings everywhere between 10 second gushers and choking the machine. I still get major channeling on almost every shot I pull. Any ideas on how to stop this?
If you can choke your machine and achieve a variety of pour times (channeling or not), your grinder is most likely not the issue. You said that your coffee is fresh, so that leaves the distribution/tamp as the most likely cause. And while it's possible to screw up the tamp
per se, it's almost always the distribution step that leads to channeling.
Do some reading or watch some videos of different distribution techniques e.g. Stockfleth, WDT and practice. If you take the pour spout base off of the Mypressi that makes it equivalent to a bottomless portafilter and the visual feedback will help you improve faster. My favourite technique is the nutating tamp, which is arguably the easiest tamp to master. This is also one tamping technique that effectively distributes during the tamp, so that you don't have to master a separate distribution step.
If you're still uncertain about the grinder, have a nearby coffee shop grind a small amount of fresh beans medium-fine (relatively coarse espresso grind). Then go straight home and try pulling a shot or two. If you still get channeling, it's almost certainly a distribution issue, not the grinder.
