by bcquinn1 on Thu Jan 17, 2008 8:59 am
Which kind of tap are we talking about?
A) Tapping the portafilter with your tamper after you've tamped, or
B) Bumping the whole portafilter on the counter after you've dosed?
In either case I don't agree that a tap is needed to avoid trapping air in the puck.
Most folks I know would tell you to do away with the "A" tap completely, or if you have to, give it the gentlest nudge with the handle of your tamper. Tap too hard, and you can spoil the seal you've created between the coffee and the basket wall, causing side channeling.
I've seen some people use "B" as a kind of quasi-distribution (Heather Perry thumps her portafilter after grinding to settle the coffee), but more often than not I've seen people use it as a way of measuring the coffee when updosing. E.g., I fill the portafilter with ground coffee - if I thump it two times, then brush off excess, I usually end up with an 18g dose. No thumps, I'm at 15g.
