WHY - Short STOP Has Better Taste ?
- BigBlaze
Most of the time ( no matter the blend ) I get better espresso taste when I "short stop"
stopping the pump 1 or 2 before produce a way better espresso.
Blonding in the cup has a unpleasant taste.
is this normal? How about water temp or pump pressure, can it be the reason?
Thank you
Thank you
- HB
- Admin
You don't say how the espresso is improved, but extraction stop tricks are covered in the Home Barista's Guide to Espresso. For example:
If you want to further diagnosis the cause, consider the test of thirds as explained in this video:
From Newbie Introduction to Espresso
It offers several other short-term solutions for various taste defects like light/dark/normal/dump/center cut shots. The better long-term solution is Adjusting Dose and Grind Setting by Taste and tweaking the temperature to control the acidity balance (higher temperature -> lower acidity with eventual bitterness, lower temperature -> more acidity with eventual sourness). Pump pressure isn't as likely to cause significant taste defects, unless it's way outside the norms (i.e., 7 bar and lower or 11 bar and higher).Diagnosis of Extraction Problems wrote:Overly bitter: Lower the temperature. Short term, try stopping darker and coarsening the grind to keep the volume the same.
- endlesscycles
I'm guessing you are hitting the "little hump" of espresso extraction by cutting short.
http://www.jimseven.com/2010/11/08/the-double-hump/
-Marshall Hance
Asheville, NC
Asheville, NC
- boar_d_laze
The post is slightly garbled (composed on a phone perhaps) and too difficult to understand for me to offer much in the way of advice.
Almost certainly not pump pressure; but water temp could be playing a part. However, since you seem to be able to resolve the problem by cutting the shot short (short of something) temperature probably isn't the sole basis of the problem.
Give us a little more to go on.
BDL
BigBlaze wrote:stopping the pump 1 or 2 before produce a way better espresso.
- Stopping the pump 1 or 2... 1 or 2 WHAT? I'm guessing
"seconds." Am I right? - before... Before WHAT? Before some ideal time like 27seconds? Or before some ideal time and volume like "the golden rule" of 2oz in 25sec to 30sec?
A very light stream is a sign of over-extraction and over-extracted coffee IS unpleasant. Stopping the shot short of unpleasant over-extraction is necessary to avoid the unpleasantness. There may be other strategies as well. Over-extraction can result from a number of things, including temperature, distribution, dose and grind.Blonding in the cup has a unpleasant taste.
Normal? Happens to everyone, but it's resolvable.Is this normal? How about water temp or pump pressure, can it be the reason?
BDL
