by Everman on Sat Aug 16, 2008 11:05 pm
What causes one bean variety to require a significantly different grind than another variety when roasted and brewed (espresso) under the same conditions?
Example: Right now I have two batches I roasted up a week ago. One is a Brazil/Yemen 50/50. The other is all sumatra. The sumatra requires a much finer grind than the brazil/yemen blend, a couple full notches on my mazzer. I've noticed the same thing when dealing with blends containing monsooned malabar, a much finer grind is required.
What is it about these beans that causes this phenomenon? The only thing I can really note is that the Sumatra beans are noticeably larger after roasting compared to Brazil or Yemen.
Right now I've been experimenting with a 50% Sumatra, 25% Brazil, 25% yemen blend and I'm seeing that the high amount of Sumatra seems to lead to unreliable pours. Sometimes the pour will go from mostly one side. I know it's not my technique or equipment, If I pull a shot of only the Brazil & Yemen blend it turns out perfect, but add in the Sumatra and things go haywire.
Has anyone else experienced this? It would be great if someone could explain why this is happening. For now I'll try lowering the Sumatra content until the pours stabilize.
