Marshall wrote:This is for you Zaffiro/Alexia owners.
Also applies to double boiler machines.
The effect of a flush is machine geometry and flush volume dependent :
With a 10mm I.D. thermosyphon tube about 60mm long, there are about 50ml in the thermosyphon circuit.
With a 5mm I.D. thermosyphon tube about 60mm long, there are about 12ml in the thermosyphon circuit.
In all cases, the group will receive boiler temp water at the inlet and ~20°F cooler water at the group exit.
Depending on the boiler inlet and outlet points, the boiler mixing efficiency, sensor location, heater response and the interval since the last shot, the thermosyphon tube could receive almost room / pipe temperature water sitting in the bottom of the boiler if the return is to the boiler bottom. In our 12ml example, the shot tail temperature will drop like a stone. If the thermosyphon return is higher in the tank, the shot tail will rise. In our 50ml example, the effect is much less.
Marshall wrote:I do not detect any drop-off in shot quality
There could be several reasons for this
Silliness aside, all rituals must be taste evaluated on an individual basis.
