dawgcatching wrote:I have yet to see a pro-level barista use the WDT at a cafe, and have been to some pretty good ones recently. I am assuming that for a skilled barista, there is no need for the WDT, and that they can replicate it without the extra time required to mix up the ground with a chopstick ect.
So, with that said, how does a pro barista dose into the PF without getting the grounds to clump up and cause an uneven extraction? What are the tricks? To my eye, it seems that they really focus on rotating the PF to get the grounds to fall evenly, but what else is going on? Then again, we purchased beans from all of these cafes and brought them home (Victrola, Vivace, and Stumptown) and were able to easily replicate or exceed the quality of espresso we had at the cafe. Still, there must be some tricks that top-level baristas use that negate the need for the WDT in a cafe setting.
As stated in the
WDT article, this techniques is designed to help the home barista overcome grinder flaws:
Grind, dose and distribution are critical to fine espresso. But unfortunately for home baristas, most high-end espresso grinders are designed for the fast-paced production of a commercial environment. Smaller capacity grinders found in even the best equipped home espresso environment may suffer from clumping, static, and uneven distribution. The home barista must overcome these hurdles to achieve an extraordinary espresso pour.
High-quality commercial grinders are prized by home baristas, but are used quite differently in the home setting. In a commercial environment, the bean hopper is kept full, with 1-2# of weight forcing beans down into the grinding burrs. At home we often weigh and grind per shot. In a commercial setting the doser is often kept full (or at least half full), whereas at home it's kept empty. For this reason, doserless grinders are much more popular at home.
As Dan notes, some grinders benefit more than others from the WDT. My modded doserless Mazzer Super Jolly (the "clump monster" in the WDT article) benefits greatly.
Along the same lines, the home barista needs to develop special techniques for managing brew temperature on HX machines, whereas in a commercial setting, a steady flow of espresso drinks may eliminate (or reduce) the need for the water dance. So different techniques in the home vs. commercial settings should not come as a surprise.
BTW, I do
not recommend the use of chopsticks, coat hangers, or any other blunt instrument to break up clumps and redistribute grounds in the WDT. My favorite instrument is still the dissecting needle, although I suppose an unfolded paper clip would also work. A blunt object like a chopstick could easily leave voids in the grounds that promote channeling, which is just what the WDT attempts to combat.
On a related note, I'm delighted to see that yogurt manufacturers have finally embraced the WDT. Here is one "WDT-approved" yogurt cup:
