- * Keep hopper filled with at least 1/4 lb to 1/2 lb of beans - about a three day supply. If I expect to be away from home for a few days I empty the hopper into an airtight container. I no longer weigh the dose. An old Time-O-Lite darkroom timer gives me a timed grind and 8 to 9 seconds always gives me about the right dose.
* Use rapid multiple pulls of the doser lever and tap the portafilter on the forks gently a few times while dosing
* Stockfleth type distribution - I tried the chopstick, the spatula and few other flat edge items but I don't see the benefit in a home environment. I do believe there's an advantage in a commercial setting if one is trying to achieve a standard of consistency for distribution when a variety of barista's with differing techniques are rotating in and out in one location.
If I recall correctly... Intelligentsia has the front line crew in their shops using a metal blade of sorts for distribution (some type of bottle opener which consists of a flat metal blade).
