Rainman wrote:...and you're an expert "whacker", right?
I think you mean thwacker.
Abe Carmeli wrote:It is my impression that the secret ingredient in their barista technique is updosing. 18 grams in a double L/M basket is considered normal by most of the baristas I worked with. At times the impression of the shower screen screw on the spent puck is so deep, it forms a small crater. The updosing is so severe, that in all three competitions the L/M technicians needed to replace the dispersion screen halfway through the competition on all the machines. The baristas will go up to 19 & 19.5 grams at times.
k7qz wrote:Abe:
Thanks for this post. I find this observation of yours quite intriguing- I'm not in your league in terms of experience but the minute I read your thoughts I said to myself "By George, that's it!" One of those things I also have seen top tier baristas do but never noticed it or had it click in my mind until just now when I read your post. Hmmm, maybe a little more experimenting along these lines is in order...
Matthew Brinski wrote:Regarding dose, I dose by sight and the compression / rotation feel while redistributing. I would find it very difficult to dose appropriately using the WDT without doing some sort of redistribution technique after it ... that is if the beans (or grinds) aren't being weighed per dose on a scale. If redistribution needs to be done after the WDT, then why bother if the results are the same or better than without the use of the WDT?
I am also not attacking the use of doserless grinders ... OK, maybe I am ..., but point is that a doserless setup, whether crafted at home or manufactured by the Holy and Divine Mazzer grinder folks, is problematic for flat burr grinders. The WDT is in effect helping fix a problem (clumping) that didn't need to be such a problem to begin with.
Abe Carmeli wrote: The updosing is so severe, that in all three competitions the L/M technicians needed to replace the dispersion screen halfway through the competition on all the machines.
AndyS wrote:Is it allowable to knock the espresso machine onto the ground when you're done to add a little "flair" to your performance?
AndyS wrote:Sort of makes the technical judging something of a farce, no? If the barista is allowed to damage the machine without technical penalty, what's next? Is it allowable to knock the espresso machine onto the ground when you're done to add a little "flair" to your performance (The Who)? Or set it on fire (Hendrix)? :o
AndyS wrote:Is it allowable to knock the espresso machine onto the ground when you're done to add a little "flair" to your performance (The Who)? Or set it on fire (Hendrix)?
