by JmanEspresso on Sun Aug 09, 2009 12:29 am
The ridgeless "Marzocco Style" basket that EPNW sells, while it is a double basket, holds more then a traditional ridged basket.. Like the Faema baskets that come with most E-61 machines. Ive got a couple faema baskets, but they dont see too much use.
As for using 14gr in the triple basket, I imagine you were having a bit of trouble leveling that off, or at least getting it even to tamp! When I use that basket, the lowest I dose is like 22 grams... usually more like 25. Thats why I bought a Synesso-sourced 18gr ridgeless basket. Its like a bid double/small triple. I can do 23 grs MAX in there. Anymore and Im smashing the screen. I like that basket a lot, I use it very often, along with my 14gr Synesso basket. Those are my two faves.
If it matters, 16grs is a low dose for me. Generally Im dosing 17-18gr for a double basket, and 20-23 for the 18gr basket. I dont use the LM 21gr much, but it does see some use. Mainly for Klatch blends, and a few home roast blends i do for high doses. The sole, underlying reason why I dont use it much, is because I BLAST through a bag with that basket. 4 shots and you use 100grs. Sometimes I pull triple that in a session, let alone what I do in a day. Plus, its a little finicky. I find that concentrating on the outer rim when distributing helps out. Also, when I switched to a convex tamper, I saw some improvements with that basket. I havent used a flat tamper since, and as of right now, dont much want to again.
If you're gonna try out the LM 21gr basket, Id start at 23grs and see what you want to do from there. If you find you like triples, but have some trouble with that basket, head over to EPNW and pick up the absolute last basket on their list, the "Synesso" 18gr basket. Id imagine its pretty close to the "real-deal", but in any case, its a nice size in between a normal double and the LM triple.
