Where do the coffee fines go?
Postby uyeasound on Tue Nov 15, 2011 2:10 pm
I have been trying different prep techniques for my grounds: WDT and sieving; but have suspected that some unseen factor is playing a role; however careful i am, and however perfectly even and fluffy the grounds appear in the basket before tamping, i seem to have variation in the flow.
But perhaps of more import is the evenness of the route of the grinds in every step after the grinder's chute. If the fines are unevenly distributed, but the larger particles are evenly spread, then will not the flow be uneven? I am here assuming the fines greatly control the flow rate.
Perhaps with more convoluted prep methods, the grounds can be well fluffed, but the fines might become unevenly concentrated within the mass.
So now i am trying to go straight from my doserless rocky to the basket, lots of knocking on the counter to evenly spread and migrate the fines down, then a little WDT to break up clumps a little, before evenly tamping. It seems to be working well.
Any comments or tips?
uyeasound
Postby tekomino on Tue Nov 15, 2011 4:16 pm
Its all pretty much speculation. If you found technique that works for you that's all that it matters.
Refuse to wing it! http://10000shots.com
tekomino
Postby uyeasound on Tue Nov 15, 2011 4:27 pm
I guess so, but i do wonder if many people find long lasting success with prep methods that involve alot of transfering of the grounds (from container to container). Basically, what i'm trying now is a vanilla method, with a small addition of WDT to counteract my doserless rocky's clumpyness; and hence i might assume the fines are evenly spread. Whereas with many transfers of the coffee, the fines may no longer be evenly distributed. Has anybody found success with a method like that?
uyeasound
Postby tekomino on Tue Nov 15, 2011 4:48 pm
I think most people don't transfer anything. Grind into basket, level, tamp and that's all there is to it.
tekomino
Postby another_jim on Tue Nov 15, 2011 4:49 pm
The fines are evenly spread because of law of large number. There are millions of grind particles, fine and not so fine; they distribute fairly evenly since with numbers that large, the percentage variations stay small. Think Las Vegas casino: with the millions of bets the house makes, their small edge in the odds always puts them ahead; with the few bets players make, some will win despite that edge.
Bad flow is about a puck that ha been unevenly packed at the gross level by the person making the shot. The easiest way to fix that is to dose less and leave some head space in the puck. But given you use a lever machine,w here you can pick the preinfusion time and pressure; you really should not have a problem.
another_jim
Postby Randy G. on Tue Nov 15, 2011 6:00 pm
My advice is to go back to the beginning and start over with as simple of a process as possible. If your Rocky is a doser model use it as a dispenser and flick away, distributing the coffee directly into the basket by moving the portafilter around as you clack-clack-clack the dosing lever. The same can be done with a doserless, but not as effectively, particularly with a Rocky. If your Rocky still has the portafilter fork on it get it off of there. it just gets in the way. To level the coffee off, tap the bottom of the portafilter in the areas and at a direction that distributes the coffee as evenly and level as possible.
To implement what Jim said, try weighing the beans and grinding per dose. After tamping there should be a good amount of headroom between the coffee and the screen. Adjust the amount of beans you grind to achieve that using a gram scale that can weigh to .1 grams. Use the lever's ability to begin the extraction very s l o w l y as a preinfusion. That pre-wetting will go a long towards minimizing channeling.
If that doesn't help, or if that grinder is making clumps that are difficult to manage, use the WDT or get a better grinder.
Espresso! My Espresso!
Randy G.
Postby uyeasound on Wed Nov 16, 2011 9:53 am
Yes, that's the process i have arrived at.
I do think the eveness of the grounds falling into the basket is important though. From that point onwards, moving clumps or larger grounds around the basket may or may not be having a predictable effect upon the whereabouts of the fines. It seems an even first contact AND an even final presentation is required.
uyeasound
Return to Tips and Techniques
