by drdna on Fri Mar 06, 2009 10:35 pm
Well, this question has been posted about a thousand times, if you search for it.
If you are going to count, start after the water has saturated the puck and begins to extract; this is when the first few drops appear.
However, don't rely on timing. What you want to do is go by the taste and volume of the extraction that you achieve before blonding occurs. If the volume is too low and the taste too bitter, make the grind more coarse. If the volume is too high and the taste to sour, make the grind finer. This usually seems to happen around 20-40 seconds, but it is going to vary with the blend of beans used, age of the beans, humidity, tamp, etc. In other words, 25 seconds is a nice starting point, but the actual "correct" number will vary with each extraction you do.
Adrian
