another_jim wrote:Here's the simplest trick: When the vampire bites, stop.
Watch where the flow enters the crema. It will lighten gradually, but at some point it will show distinct pale spot (the "vampire's bite" if you use a double spout). This is the absolute maximum you want to run the shot.
Heather Perry is one of the best baristas on the planet, and recommends going this far. For most coffees and shot making drills, this level of blonding will produce a slightly dulled shot, and you would be bettr off cutting earlier. But it's very easy to find out when the vampire bites, and work back from there.
If some time,you could put a video,we,(I mean myself),would appreciate this.
Regards,
Theodore.
