Zendel wrote:Your extraction time should be in the neighborhood of 25-30 seconds. I think the key to stopping the extraction is the color of the flow.
Zendel and HB, thank you for your replies.
I have seen many espresso extraction videos, but sadly not many with a pressurized portafilter (which is what i'm stuck with).
have a look at this video please....
the espresso extraction time in this video is 12 seconds from the moment that the machine is turned on to the end of extraction.....
it is in the region of 8 seconds if you start counting from the time that the espresso starts appearing.
(agreed, the guy doesn't tamp at all (which deserves a question on its own, considering his expertize), and some of that crema is fake... but look at the espresso... it looks good)
would you call this guys espresso shot under-extracted ??
I've experimented with various grinds (too fine to even get stuck in my portafilter holes) and tamping pressure (have tamped so much, was almost thinking my portafilter is bent at the bottom yesterday!)
and i've never been able to stretch the extraction time into this 25 to 30 seconds region.
it's as if my machine is just programmed to give me a fixed water flow rate.... and the more i try to lower the flow rate, the louder it gets, and the worse the espresso turns out to be.
