What size basket for 20 gram dose?
Hi,
I want to use a 20 gram dose.
I have Marzocco 17 and 21 gram VST baskets that came with my GS3?
Which one would be best to use?
Thanks,
Brian
Thanks,
Brian
I didn't realize VST had 21 gram baskets (I think you mean a Strada). VST does have a 20 and 22, which would match you perfectly.
for a normal basket I would say to updose the 17 but seeing as they are VST (or strada), I recommend not updosing and using the 21.
Thanks. I have what came with brand new GS3.
Label with 17 and 21 on basket.
I'll try the 21.
I'll try the 21.
- JmanEspresso
VST and Strada baskets should be used within +/-1gram of the advertised size. No more variation than that.
If you want to get a traditional basket for 20gram dose, the 18gram Synesso ridgeless(the big synesso double), is ideal. Its my most used basket.
