What should espresso really be? Do we have it wrong? - Page 3
Postby Bluecold on Mon Aug 31, 2009 6:23 pm
another_jim wrote:In the 1950s, espresso was simple: a short cup of black coffee made to order fast.
I believe this statement is still relevant now. Espresso is great for a quick boost. One good* espresso can completely reinvigorate me and can get me going again. I don't sip carefully, I just make it fast**, drink it fast and get going. This -I feel- is where espresso really comes into it's own. If i want my coffee slowly I feel other brewing methods are more suitable to that.
I think that the speed aspect of espresso gets lost sometimes. Skimming crema comes to mind. And latte art. Maybe I have a negative disposition to it because i can't steam milk with the Peppina, but i don't think latte art has anything to do with art or espresso. I do like latte art as a sign of attention paid and as an indication it probably won't be horrible dreck. Also, it impresses other people and makes for a fun pastime so i can't (and won't) fault anyone who pours figures in his cappuccino.
*Bad espresso makes me sad.
**Not cutting corners in quality of course. Mostly streamlining my preparation method.
LMWDP #232
Bluecold
Postby corsoemmanuelledue on Thu Sep 03, 2009 3:14 am
Bluecold wrote:I think that the speed aspect of espresso gets lost sometimes. Skimming crema comes to mind. And latte art. Maybe I have a negative
Well said. It is supposed to be casual, just enjoy a great booster shot and move on.
corsoemmanuelledue
Postby peacecup on Thu Sep 03, 2009 7:52 am
Tim,
Just try one of these...
The Arrarex Caravel
ciao
PC
LMWDP #049
peacecup
Postby TimEggers on Thu Sep 03, 2009 8:14 am
I'll admit I don't use my lever nearly as much as I would like. I hope to have a Vario here in the near future and with two grinders I hope to have both machines dialed in and ready to go head-to-head... :D
TimEggers
Postby michaelbenis on Thu Sep 03, 2009 9:19 am
Following on from Bluecold's response to Jim's "short cup of black coffee made to order fast"
I'd have to add that for me the magic of espresso is that here is something you can prepare quickly on demand, which nevertheless, for all it's diminutive volume, won't let you simply knock it back in a thoughtless hurry: when made properly, it draws attention to itself.... you are forced to savour it... for a second you take time out...
Magic!
LMWDP No. 237
michaelbenis
Postby TimEggers on Sun Sep 06, 2009 5:50 pm
To follow-up:
I pushed my brew pressure up until the espresso started to get grainy in body and slowly backed it down until the grittyness went away (7.2-bar or so). The body is smooth creamy and the shots taste sweet and full flavored (not under extracted).
The espresso has never been so good, and my baskets don't require a lot of attention to get even pulls...
TimEggers
Postby TimEggers on Wed Sep 23, 2009 2:21 pm
another_jim wrote:A food science lab at the University of Salamanca published some consumer studies a while back and got a near tie with 9 and 7 bar espresso, while the 11 bar shots were thought a lot worse.
But the overall impression I get from all this work is that pressure is not a major game changer, more a fine tuning variable. I think you are the first who's developed a really large preference for lowered pressures on a pump machine.
Well "we" don't have it wrong, I did.
Last night I reconsidered my pressure setting. This morning just out of curiosity I put the pressure back to 9-bar/blind basket.
For a moment I thought I was going to have to adjust finer to slow the time down for the higher pressure. I decided to grind and pull a shot just like I was at 7-bar to see how ridiculously fast the shot would actually be. What stunned me was that the shot wasn't fast, ok maybe a couple seconds but at 7-bar my shots were a typically 30 seconds, now they are closer to 26 or 27 seconds.
The flavor was very good, not assertive at all. Much more crema (obviously) but the shot remained sweet and quite delicious. I'm actually most surprised at how little the shot did change even after the 2-bar adjustment upward.
The way I figure it is that I've been grinding too fine all along, making the shot gritty in body and flavors overall bad. When going to 7-bar I had to loosen the grind in order to get a decent shot time, that's when the shots also tasted much better. So all along it appears it was my grind, not my machine pressure.
Interestingly I still use the grind, dose, level and tamp and the shot beads evenly and flows dead center. That's what really surprised me. I can't explain it (and in many ways) things are just falling into place.
Probably obvious to most of you, and Jim you were right. I don't think I was having a preference for low pressure shots, I was liking the espresso once I was forced to produce a better grind. At 9-bar the shots are just as lovely as they ever have been, it was my grind (and my ignorance) that was holding me back.
TimEggers
Postby another_jim on Wed Sep 23, 2009 2:38 pm
Unanimity has been restored. I'm not sure whether to be happy or sad.
another_jim
Postby Peppersass on Wed Sep 23, 2009 2:43 pm
TimEggers wrote:What stunned me was that the shot wasn't fast, ok maybe a couple seconds but at 7-bar my shots were a typically 30 seconds, now they are closer to 26 or 27 seconds.
Interesting. Once again, grind turns out to be the critical factor.
I was reading in Rao's book that at a certain point, more pressure will actually slow the flow rate, probably due to compression of the cake. So maybe you are close to the turning point at 9 BAR.
On the surface of it, it would seem the finer grind overextracts, which is what you didn't like. What kind of shot time did you have with finer grind and 9 BAR? When you say gritty, do you mean literally, like a lot of fines in the cup, or just way too much body?
Dick Green
Peppersass
Postby TimEggers on Thu Sep 24, 2009 1:19 am
Something I did notice today is that the higher pressure shots were hotter in the cup, even after a rest they were still quite hot. Indicating to me too high a flow rate (the coffee was unable to draw some of the heat from the water because the water passed by too fast).
While I was surprised at the results I did notice some things were just "different" than before. The coffee was the same (the same flavors) but the character was different. The shots seems a little less sweet and heavier in body.
Tomorrow I'm going to try a slightly finer grind to try to slow the flow rate down, but I'm already giving up quite a bit of sweetness (but gaining the creamy body).
I'm still in the "learning" phase whereas I feel like a toddler learning the colors, soon I'll be able to use those colors to finger paint.
I can't say what setting I prefer (at this point) and I do have some measuring devices en-route so I can attempt to collect some more meaningful data. So far I've had amazing espresso at 7-bar(ish) pressure, some of the best I've had the pleasure to drink. At 9-bar the character is a little different and the body amazing, but I can taste the sweet blueberry turning a little bitter/harsh for me. Instead of sweet berry its wanting to roll into a bitter dark fruit. I saw the same in the chocolates, sweet milk chocolate became a more bitter/dry dark chocolate. Still good, but just a little different.
I'm going to spend a few days here and see where I can take the coffee. I'm beginning to wonder what personal significance I place on "body" vs "flavor" for my espresso. Frankly I'm beginning to doubt that I prefer a heavy creamy body/crema, especially if it sacrifices sweetness/flavor clarity.
Curious what the flavor changes are between a slow low pressure flow rate and high fast flow rate shot? Nonetheless I'm still having a lot of fun and really learning a lot about not so much espresso, but what my strategy is in producing the beverage, or in other words how I want to interpret the bean.
TimEggers
PreviousNext
Return to Tips and Techniques
