www.baratza.com: skilled in the art of grinding
What kind of a steam tip is this?
Postby gauchogolfer on Sat Mar 07, 2009 12:15 am
I've just bought a NS Oscar, and I've not been having much luck with milk foaming (even though I've been practicing with the water/soap trick I found about here). I'm wondering if I should look at different steam wand tips. To start off, I thought I'd find out exactly what I'm working with at the moment. It's got a huge hole on the bottom, and two pretty substantial ones on the sides. Am I going to have any luck with this one, or should I make life easier on myself and get a new one?
Thanks.
gauchogolfer
Postby caeffe on Sat Mar 07, 2009 2:53 am
Interestingly, I just called NS this morning to inquire about a replacement stock tip. I had heard that they also make a steam tip with reduced pressure. I find that I can foam milk easier using my Elektra MicroCasa A Leva which has two outward facing holes.
That steam tip of yours doesn't look at all like the stock tip for NS Oscar. Not only that but the 2 holes which are perpendicular to the thread axis look mighty huge. You'll probably run out of steam pressure quick.
The stock tip for the Oscar has 4 holes on the bottom that are angled outward, with holes that are small (or large) enough to allow you to jam a toothpick into it.
OEM stock tips from the factory IIRC are <$5 (+shipping of course). Check the Nuova Simonelli website, p/n for it is 73006003. I was told by a tech on the phone that the 'reduced pressure' steam tip is 73006003.1 It wasn't listed on the Oscar price list nor their price sheet.
See: http://www.nuovadistribution.com/pricing.html for price on the stock steam tip.
See: http://www.nuovadistribution.com/...ts%20Breakdown.pdf for the parts breakdown which will show you the part for the steam tip.
LMWDP #162
caeffe
Postby gauchogolfer on Sat Mar 07, 2009 11:11 am
Thank you so much for the info! I was looking at espressoparts.com, and suspected I didn't get the stock tip with my machine. I'll see about getting a new one from your links.
And yes, steam pressure seems to suffer with this setuo.
gauchogolfer
Return to Tips and Techniques
