What is the correct method for shot timing?
Postby canyncarvr on Mon Nov 08, 2010 7:40 pm
From here:
HERE..
When a shot is timed, the timer starts (i.e. 0 time) when the pump button is pushed.
That's not from a 'gospel' thread..and not meant to be. It is what I've thought to be generally accepted shot timing and something I've read more than a few times.
But...browsing through links on the Resources page, I read from here:
For 1.5 ounces of espresso, the extraction should take between 23-30 seconds where the time starts when the espresso begins to flow from the spouts.
(emphasis is mine)
For the sake of argument, consider a perfect shot to be 27 seconds. I think there would be general agreement that in light of taking that as fact, a 19-22 shot would NOT be perfect..and neither would a 32-35 second shot.
The differences? The 5-8 seconds that is fairly common from 'pump on' to 'flow'.
I'm not trying to pick the proverbial nit, but the difference between the two points of view seems quite large to me, certainly large enough to make a good cuppa a bad one.
Which is it? IS there consensus on the issue?
canyncarvr
Postby Bob_McBob on Mon Nov 08, 2010 7:55 pm
A lot of people seem to go by when the pump is activated. It's further complicated by pump type, pre-infusion, and other factors. You are going to get a lot of replies telling you shot timing is only a basic guide, taste your shots, etc.
Chris
LMWDP #295
Bob_McBob
Postby canyncarvr on Mon Nov 08, 2010 8:07 pm
Yes. I understand taste is the point of it all. I understand there are a good number of variables that figure into that result.
When tamp levels of +/-1mm, coffee doses measured in .1/g, temperatures of +/- a short handful of °s, and stepped grinders being unnacceptable due to the coarseness of their adjustment...THIS 'difference' seems quite a bit outside the 'ol box.
canyncarvr
Postby cafeIKE on Mon Nov 08, 2010 8:59 pm
Like all other variables, timing is set by the coffee and pull. It's only applicable to what you are pulling at the moment.
I switched coffees today : ½ turn finer, +0.5g, +1°F and +5s from last week.
Notice : NO mention of tamp :wink:
cafeIKE
Postby mitch236 on Mon Nov 08, 2010 9:03 pm
I'll give you one idea where timing is very useful. For me, once I get a bean dialed in, I set my shot timer to the time I want the shot to run. That way, I don't need to really watch the shot pour and can steam milk instead while the shot is pulling. I start my timer the instant I turn the pump on.
mitch236
Postby canyncarvr on Mon Nov 08, 2010 10:28 pm
cafeIKE wrote:Like all other variables, timing is set by the coffee and pull. It's only applicable to what you are pulling at the moment.
Whew! I was getting worried there! If a tamp change was in the mix, I'm afraid I simply couldn't have handled it. :wink: ..indeed!
canyncarvr
Postby another_jim on Mon Nov 08, 2010 10:38 pm
Machines vary from 3 to 10 seconds dwell time (from pump turn on to first drop). Since half the people say go from the pump, and the other half say go from the first drop, I give my shot times based on half the dwell time plus all the flow time.
It may not be right, but it seems the most reasonable way of comparing long dwell with short dwell machines.
another_jim
Postby BradyButler on Thu Nov 11, 2010 6:55 pm
FWIW, the chronos pads on the Linea AV start timing when you push the button.
Initial contact between coffee and water seems like a relevant thing.
Most trainers that I know teach to start timing when you start the extraction.
LMWDP #379
Carolina Espresso Services - "Quality Service for Espresso Equipment"
BradyButler
Postby another_jim on Thu Nov 11, 2010 7:43 pm
BradyButler wrote:Initial contact between coffee and water seems like a relevant thing.
True, but is it initial contact with the top of the puck, middle of the puck, or bottom of the puck? If the first drop appears, for instance, after seven seconds, then the initial contact between water and coffee is spread out over those seven seconds.
another_jim
Postby mitch236 on Fri Nov 12, 2010 9:22 am
Wouldn't you agree that timing is relative, assuming normal flow? IOW, I only use roaster's recommendations as a starting point. I find the timing that works for me and so long as I am consistent, that time should work shot after shot. If I tell you that I use 26 sec to brew 19.5gm of Vivace Vita, that time would only be relevant to me. Your time will be different based on many variables. Alternatively, if you set wanted to set up an experiment as another_jim did I think he has the best compromise for achieving repeatable results.
mitch236
Next
Return to Tips and Techniques
