I have a Bezzera BZ10, with the original 14g basket and I buy the original tamper, made by Bezzera (link). But I noticed immediately that the tamper don't fit the basket! Look here:
If I press in the middle, 1-2mm of grind around the tamper, remains incomplete pressed, and the coffee stick to the edges of the tamper. Must to knock, and press for another two times to cover all the surface of the puck.
The vendor say that "this tolerance between tamper and filter is absolutely wanted, it does not matter if there is 1mm space at the side."
What do you think? Is a matter of technique or is better to sell this tamper and buy a Reg Barber (for example) with the exact fit diameter?
