triptogenetica wrote:I've settled on a similar compromise regime - water backflush often (though i can't promise i remember after every session), then puly caff every 2-3 weeks. Nowhere near enough in a commercial environment, but suits me at home.
I bet you clean far more frequently than they do in most commercial environments. The compromises I make are because of the long MTBS (mean time between shots) that allow any residues to age, while most commercial shops base their schedules on short MTBS, and lots of shots on a daily basis. I will pull a water backflush after each shot, or each session if I know that I'm gonna be back in less than an hour or so, and my PF's. baskets, and pitchers (along with the towel used for cleaning the steam wand) get, at the very least, a good rinse. Usually they all get an enthusiastic scrubbing, sans any detergent or soap, and get a good bath in leftover Cafiza or JoeGlo once a month or so, at the same time I do a cleanser backflush.
You're probably pulling fewer shots between cleanings, but keep to mind that your machine sits far more than any commercial machine. Try not to let stuff 'cook' on!
