by ChrisC on Wed Jun 25, 2008 2:23 pm
Podster, Marshall is right, something is crooked in your dosing and distribution. If you figure it out and get it straight, and you're still seeing the screen touching the coffee BEFORE brewing, you also need to dose less coffee. (The screw leaving a slight imprint, while not ideal, seems to have less effect on extraction, so don't stress about that too much.) The Silvia is notorious for a lower grouphead that doesn't leave much headroom between the screen and coffee at higher doses. I actually found that it was impossible for me to dose more than I wanted and sweep the top of the basket off evenly -- it always resulted in too much coffee in the basket. Now I weigh 20 grams or less (I found 20 was the functional max) of beans and grind that into the PF with a yogurt cup, WDT (which generally leaves the top of the coffee slightly below the top of the basket), tamp (pretty hard, and very hard if using close to 20 grams), and insert.
I wouldn't worry about soupy pucks, etc. Just work on getting something you like the taste of. I have found I can dose 14 grams (which many think of as a standard dose for a double) and still get a very good shot by grinding finer. By taste I generally prefer the shots at I get 18-19 grams though.
Another thing for all Silvia owners -- the stock double basket you get is pretty crap and makes nice extractions unnecessarily difficult. One of the biggest improvements I ever saw in my coffee was when someone gave me a La Marzocco basket. If I were you guys, I'd buy one of the ridgeless ones (slightly easier to pop out when you need to).
