jesawdy wrote:Hmmm... no. Are you certain it is coming from the 3-way valve? How much water? If the expansion valve exhausts to the drip tray (and I think it does), this might indicate that you are getting an overpressure condition and that might explain some of your frustrations.
Also, unless you've been grinding rocks, there is no reason you should have to be replacing burrs at this pace.... I'll agree that the first set looked a bit messed up. A set of these burrs ought to be able to grind 1000+ kilos before replacement.
The old pourover vibe Juniors, before they put all those needless electronics in, the versions with the sight glass, have an overpressure valve (OPV) just behind the front panel when removed. It looks like this:
(this was taken before I descaled it years ago)
At least as sold in the USA circa 1995, this functioned only as an extreme overpressure valve with exhaust of excess water into the drip tray; it is, however, fully capable of acting as a *real* OPV. You would need to attach some foodsafe tubing (e.g. silicone) onto the nipple on the opposite side, not pictured, then run the tubing back into the pourover tank. Then, with the aid of a portafilter manometer (pressure gauge attached to a portafilter), you can adjust the pressure via the big screw with a flat screwdriver, and the extraction pressure will be adjusted and some water will return to the pourover tank during extractions, in the process.
IF your OPV has been set at one position for years and years and years (as was mine), changing the setting may cause a very loud squeal to come out of the valve when shots are pulled. It sounds like a pig who is awaiting slaughter and knows of its fate
You could try minor adjustments to see if it will go away, otherwise you will have to make a new rubber seal to put inside the valve itself, which will require dissassembly; it is simple inside, just a big screw and metal piece holding the rubber seal. Clean everything up inside with a little bit of sandpaper, just to be sure that rough edges aren't causing your problems.
I used an old group gasket for the rubber I used to fabricate this, with a box cutter type knife. You could buy a new rubber seal if your Cimbali dealer stocks it (the part I'm describing is several mms in width and about 1/2cm in thickness, round in shape). My experience with a new rubber seal was that the squealing was not eliminated, but with my custom made seal, it was.
ken
