by cannonfodder on Fri May 04, 2007 10:25 pm
Evening Ozzman. Those beans looked good, a nice northern Italian style roast, but looks can be deceiving.
Your La Cimbali grinder is more than capable of choking your machine, unless you brew pressure is off the scale high. On thing that comes to mind, if you beans are truly fresh, you may have a case of a 'blond gusher'. When beans are super fresh (say 2 days post roast) they will produce an abundance of Co2 when used.
Even with a very fine grind, the shot starts looking good, then quickly gush blond crema. The crema will be very abundant but the texture will be off. The bubbles will be twice the normal size and clearly visible. The crema will also go flat very fast. You could pull a 3oz shot that is all crema; it then goes totally flat in a matter of seconds leaving you with a bitter little 1oz of espresso. Getting the flow right is nearly impossible, and even if you do it will taste like someone put baking soda in it.
If that is the cause, then in two days the beans will finish out gassing and the extraction will settle down. As to Dans point, Paradise Roasters has some wonderful coffee and if you can get some shipped out your way, you wont regret it.
