mrgnomer wrote:In reference to the Coffeegeek tamping article a point is made that tamping a full basket only compacts maybe the upper 1/3 or so of the grinds. Below that there may be not a lot of compacting going on so if the bottom of your basket isn't distributed well when extractions gets down there the pressurized water will find a path of least resistance.
We were discussing Mark's article at our usual Friday espresso get-together, specifically about how force is transmitted through different mediums. Ironically Lino had a meeting later the same morning to discuss the minimum
nutation necessary to properly compact asphalt, the same principals applying loosely to coffee pucks. I won't attempt to summarize Lino's explanation, other than to say the multiple angles of attack contribute more to the tighter compaction than simply how hard one presses; this may also explain why Michael Teahan's SCAA presentation reported no significant difference between a 30 and 300 pound tamp.
