HB wrote:that was Lino's point about nutating action and asphalt compression.
Well, the two aren't really that comparative. Asphalt is no longer compressible when the solids in the mix are all touching and there is no longer room for movement. Once this happens you're done unless you increase the pressure enough to crush the stones in the mix. This may be true for coffee grounds as well, but that would mean that 30lbs is as compressed as the puck can be, and that the bean fragments can not be any closer to one another, nor can they be deformed or compressed any further. My empirical evidence tells me that this isn't true.
