by sprint jinx on Fri Oct 29, 2010 2:44 pm
If you really think about what is being hypothesised here, one can certainly come up with a few variations on how to achieve good results of outputting the desired amount of grounds into the PF, through time or weighted dose.
I just want you all to ponder what industry standards achieve on a regular basis for the food or liquor industry. I work for a large company that does exactly what you are pondering, putting loose granular substance of precise size into packages, but, at say 100 times a minute, sometimes 400, and on a few select machines, its 800 a minute, into pouches or bottles. Dosage is exact, dialed in so that it hits a target, by weight. Overfill costs millions and I'll stop there as the analogy goes downhill.
It might be nice to contemplate a few group ideas that could eventually lead to a paring down to some diy solutions.
Here's one idea- my non digital grinder switch-
Using a see-saw type device, with the PF basket at one end, small weights on the other. The coffee exiting the grinder fills the basket until the weight of it tips it down (near 14g), whereby a switch is triggered and it shuts off the grinder. Tweaking the weight amount would allow for precision on the grinder kill. Viola.
Another -
electric eye cup-
The grinder fills a clear cylinder, that has an electrical eye passing through it, like on garage doors, only more precise. When the ground level is high enough in the tube, it triggers the eye and shuts off the grinder. Weighing the result and then raising or lowering the eye, yeilds the desired dosage. Of course, the cone shape of the fill would need a vibration pad under it, to keep the grounds somewhat horizontal.
enjoy-
