WDT to Stockfleths Move - Page 2
Postby HB on Tue May 17, 2011 4:32 pm
innermusic wrote:How exactly would you do that?
Er, move the portafilter handle as the basket fills? Start at 8 o'clock, then 6 o'clock, 4 o'clock, repeat. Or remove the basket and rotate as shown in Stockfleths Move for Dummies:
Starting at 0:48s in this clip
Postby innermusic on Tue May 17, 2011 5:38 pm
What I meant was: any shaking of the PF involved? Stopping and starting? Etc.
innermusic
Postby HB on Tue May 17, 2011 6:24 pm
The goal is to avoid the need to redistribute, since that is essentially correcting for dose "landing" errors. Rotating the portafilter while dosing is an obvious means to that end. The Vario grinder is slow enough that you should have no trouble keeping up (it's a lot trickier with a Mazzer Robur, for example, that grinds a double in 8 seconds). Don't overthink it.
Previous
Return to Tips and Techniques
