On the right is the grind coming from my Ascaso i-mini that I bought used. Dont know how much use it has had. The coffee used is not freshly roasted. Should I be grinding finer? The grinds are about the size of regular sugar (not powdered)
Here below is what the grinds from Starbucks (left) and from the I-mini (right) after they have been smudged on the paper. My concern is that there is a bit more "powdery" leftover grinds with my grinder. For reference, this powder would also appear when grinding freshly roasted coffee (black cat) Is this a sign that I need to either adjust the grind, change my coffee or change the burrs?
Any comments on my dosing
Here is what the puck looks like after infusion ( a bit on the soggy side )
Finally, here's a (low rez) video of the pull. Please comment on whether (if you can see well...) you notice that the shot gets watery at the end.
