Thanks for the link. Excerpted for easy reference:
Mark Prince wrote:I'd load up a filter basket with a central pyramid like cone, and avoid touching the coffee at all costs. I also would knock down the loading bed of coffee while grinding - one or two knocks at 1/3 full, another one or two knocks at 2/3 full. The result was a nice, even cone of coffee in the filter basket. This is why I liked the Anfim Super Caimano grinder so much: it can dose a nice even cone every time.
VST baskets or not, I recommend dosing the basket as evenly as possible. The goal is to have a uniform layer of coffee that requires little or no manipulations. The Stockfleths Move and its ilk are essentially distribution
corrections; the less you need them, the better. Moreover, if you want to updose by tapping mid-dose as Mark describes, I again recommend "paying careful attention to the landing" (per Jasonian) so the tap doesn't result in a denser layer near the center as would be the case for a pyramid-like cone. The telltale sign of higher center density is uneven, donut-shaped beading.
For what it's worth, I've used the VST baskets at Counter Culture Coffee's espresso lab for the last few months. While I haven't done any side-by-side tests with them and the stock La Marzocco baskets available for years, I haven't noticed any requisite technique change.
