www.baratza.com: skilled in the art of grinding
VST Filter Basket Dosing Issues? - Page 8
Postby CrayonShinchan on Mon Aug 15, 2011 12:59 pm
Spitz.me wrote:Dan, maybe my Vario is a POS, but mine slips out of optimal grind settings often enough. I actually find that it happens all at once, just one day it'll be horrible, but it takes me a bit of trial and error to really figure it out. Sometimes you need to change dose as the bean ages, right? So, I don't know what or if you need to worry about anything depending on when you bought it. Mine was a 'first-adopter' purchase and it's also the second, as the first was horrible out of the gate with slipping sliders... People can speak to the customer service and grind quality they get with the Vario and Baratza products, but I'd rather something that's reliable.
I received a tool from Baratza that allows me to 'move the burrs' back into proper setting...
Sorry for the OT in my own thread.
Sorry to bring up an old thread and sorry if OP has already moved on from this, but it sounds like the Vario just needed those shims that Baratza offers, especially if it was a 4500 serial number or below.
As far as spritzing with the VST, I also experienced this quite a bit but I remedied it by making sure my grind was finer than normal, distribution was nice and level, and tamp was a little firmer than I normally do (normally, it is less than 30lbs). Also, I felt that beans that were too fresh resulted in major spritzing.
CrayonShinchan
Postby mitch236 on Mon Aug 15, 2011 1:07 pm
After a couple of months playing with my three VST baskets I found the 15gm basket harder to work with than the larger two (18gm and 22gm). I'm not sure why this would be but I find myself using the higher dosed baskets and resorting to my LM or Synesso baskets for lower dosing.
mitch236
Postby johntaus on Mon Aug 15, 2011 4:56 pm
johntaus wrote:Well I have tried downdosing to the rated capacity of the filter basket and a grind finer than I would think is right, concave in the middle and it kinda works. May need to adjust the grind finer yet but the pour looks real great on the naked, time is good at about 25-30 seconds. The taste is still not quite balanced - too much of the sour notes. The puck comes out gooey rather than solid.
regards
JohnT
Well I gave up on dosing to "spec" - overdosing simply tastes better! Now using the 15g basket and except for the finer grind treat it the same as any other filter basket as far as my prep but manufactured better than anything else on the market.
Don't know in a home environment whether it makes any difference at all but it was an interesting journey!
regards
JohnT
johntaus
Postby nixter on Mon Oct 03, 2011 12:23 pm
Peppersass wrote:Not to be cynical, but it seems our fair vendors have found a way to triple the price of filter baskets and quintuple the price of steam tips. Significant improvements, or $200 AC power cords for audiophiles? :roll:
Of course, I ordered a couple of VST baskets to try. After all, I have to keep up with the Joneses. But I resisted the Foam Knife steam tip! :D
Funny, when trying out my brand new VST this weekend I coudn't help think of Monster "High Speed" HDMI Cables. :) Anyhow, my findings thus far with the VST are this... it's definitely a filter basket.
nixter
Previous
Return to Tips and Techniques
