Peppersass wrote:I think you cut it off early. The cone was just starting to collapse, but the color hadn't lightened very much. But it's impossible to tell by looking at a film. You have to let taste determine when the extraction has completed. Try cutting off
the shot at different times, noting the shape and color of the cone when you turn of off the flow, then taste the espresso.
Damn. I thought it would be too late for sure.. I usually cut it off a few seconds before that. Good to know.
Peppersass wrote:I generally find that when I've cut off the shot at the right time, the top of the crema is a nice cinnamon color with one or two small blotches of yellow that have dripped off the screen after I cut off the flow. But it really depends on the coffee. Some coffees may taste better cut off earlier, others may taste better cut off later.
I don't know your machine -- I heard two distinct motor sounds at the start of the shot. Were you using some sort of preinfusion? I counted about 34 seconds from the second motor sound to the end of the shot.
Here is my procedure:
- Warm up for 30 minutes
- Grind, WDT, Tamp, Set aside
- Steam Milk
- Run brewhead for about 10 seconds, or until thermostat clicks off
- Turn steam switch on, set portafilter into machine
- Wait til thermostat clicks on, start brewing
- Wait 3 seconds, turn off steam switch
- Brew
So you were hearing me turn off the steam switch.
Thanks for the tips again, I'm going to pick up a 15g basket and start to experiment with all of this in mind.
