Excerpted from Al's rule: "...for every 10ml of espresso above 60ml, subtract 1 second of extraction time.....So, my 50ml ristretto should extract for 31 seconds. The 90ml lungo I make for my wife will need to extract for only 27 seconds"
I know these are just
guidelines but is he really saying he can adjust his grind to get a change in flow rate of 10ml/sec (for a double)? That must require incredible finesse: the difference here between a 45ml ristretto and 90ml lungo is just 4.5 seconds! Then to be able to judge that by eye... However, if the practical part of the rule is this: fast pour stop short, slow pour stop long then that seems more feasible, at least to a newbie.
Anyway, thanks for the clarification Jim, I'll have to disassemble my grinder and adjust it internally to get it to grind finer than it does now, but if it works and improves the shots I'll post another video.
cannonfodder wrote:I knew the general idea of longer times for the lower volume but I did not realize that that much time was needed. I would have thought that bitterness from over extraction would be a problem.
I'm not very experienced at describing individual flavours in coffee (I'm still new to espresso) but in this case the shot wasn't bitter, more... sweet, reminded me of marzipan. Whether or not that is what it was supposed to taste like is another matter, I've never had a real ristretto.
Thanks for the continuing advice
DC
